Xantia hose
froggy
(Donor 2026)
x 4
Xantia hose
Unread post by froggy »
Hi, just found a slpit in this hose. anybody know what its called and is it a Citroen only part ?
Thanks Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 8309
Re: Xantia hose
Yep, a Dealer only part Froggy and a very common failure...
They're not overly expensive. If we know exactly what car, one of use can quote a part number from Service.Citroen for you...
x 1484
Re: Xantia hose
"They're not overly expensive. If we know exactly what car, one of use can quote a part number from Service.Citroën for you..."
:lol:
Assuming its the Xantia as per the sig then service.citroen says:
Part Number Description Price excl. VAT Price incl. VAT
000014247C AIR HOSE 33.02 GBP 39.62 GBP
Ouch. Duct tape to the rescue me thinks!
froggy
(Donor 2026)
x 4
Re: Xantia hose
Thanks guys, it"s a 1997 T.D. (Temptation)
Terry .
Terry
x 8309
Re: Xantia hose
RichardW wrote: Ouch. Duct tape to the rescue me thinks!
Works for me :-D Good duct taper can be surprisingly effective and long-lasting. I did a repair on a small split in one of Rattiva's turbo hoses with it and it's still going strong despite actually having a new hose ready to fit..
The key is to use the best quality stuff you can lay your hands on...
x 5654
Re: Xantia hose
Or what you can find at work :wink:
Worked fine to stop my daughter's house flooding like it did seven years ago. Small weep around the glass and through the corners of the beading was all, the houses adjacent were washed through and floors, furniture etc ruined. The next door neighbour was shoveling water out with a snow shovel.
The water rose another eight inches after that but my phone battery was done by then.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
What about self-amalgamating silicone wrap? It's getting cheaper, and would look nicer than duct tape.
Jaf
x 42
Re: Xantia hose
Unread post by Jaf »
Mine went in the exact same place. Guess every time the air filter is changed it puts pressure on the hose.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
xantiaBFY
Re: Xantia hose
Unread post by xantiaBFY »
Hi
Being here in Malaysia...its duct tape for me...;[
regards
xantiaBFY
