Rapidly blinking right turm doing my nut
boristhespie
x 4
Unread post by boristhespie »
Okay so left indicator okay. The right decided to double speed. Someone said it could be to do with bulbs. I did have YET ANOTHER bulb go but I just changed it and it's still having a blinkin fit (see what I did there ;).
Is there a setting maybe. I know some european cars have this speed of blinkin but really it is really getting on my nerves.
C'est pas possible!
x 1496
Re: Rapidly blinking right turm doing my nut
Are all 3 bulbs actually working? If not, then a COMS 2000 (the switch unit) fault is probably likely - it's a pity you just sent the other one down the road.... #-o
x 1473
Unread post by xantia_v6 »
Check that the replacement bulb is the correct voltage and wattage.
boristhespie
x 4
All three bulbs working. Tho leccy faults are intermittent.
C'est pas possible!
x 5675
Bit of a long shot but operate the hazard light switch a dozen times.
Sulla
Unread post by Sulla »
I had this on my Xantia, it ended up being a faulty connection in the indicator stalk, fitted a replacement one from the breakers and problem solved.
Xantia 2.0 HDi LX (my car)
C1 1.0 VTR (wifes car)
Previously owned:
Xantia 1.9 TD Temptation 2
C4 1.6 LX
