Is there a setting maybe. I know some european cars have this speed of blinkin but really it is really getting on my nerves.
Rapidly blinking right turm doing my nut
boristhespie
- x 4
Okay so left indicator okay. The right decided to double speed. Someone said it could be to do with bulbs. I did have YET ANOTHER bulb go but I just changed it and it's still having a blinkin fit (see what I did there
C'est pas possible!
- x 1485
Re: Rapidly blinking right turm doing my nut
Are all 3 bulbs actually working? If not, then a COMS 2000 (the switch unit) fault is probably likely - it's a pity you just sent the other one down the road....
- x 1441
Check that the replacement bulb is the correct voltage and wattage.
boristhespie
- x 4
All three bulbs working. Tho leccy faults are intermittent.
C'est pas possible!
- x 5666
Bit of a long shot but operate the hazard light switch a dozen times.
Sulla
I had this on my Xantia, it ended up being a faulty connection in the indicator stalk, fitted a replacement one from the breakers and problem solved.
Xantia 2.0 HDi LX (my car)
C1 1.0 VTR (wifes car)
Previously owned:
Xantia 1.9 TD Temptation 2
C4 1.6 LX
Previously owned:
C4 1.6 LX
