C5 Boot Suspension Switch failure.
Alec B
Hi all, is this an easy fix. It 'bing-bongs' but the suspension doesn't move. We don't use it much but my kids like playing with it so if it's easy and cheap I'll fix it? We have just had the pump replaced if that has any links to problem, as it worked before it was replaced. Regards Alec.
Current Car
C5 Estate VTR 1.6HDi 2005 S2
Previous French Cars
Pug 205 Gti 1.6 1985.
Xantia Estate LX 2000 90bhp HDi
Xsara Picasso VTX 1.6 HDi (92) 2007
old'uns
- x 127
Re: C5 Boot Suspension Switch failure.
never had mine 'bing-bong' but check if 12v socket still works, all on same fuse. which one depends on spec, easier to pull all out & check
Alec B
Old'uns you've never had the bing-bong well you are missing out, well it's actually more of a bing-bing if I'm honest, but never the less the suspension still doesn't move. I'll check the fuse, that should have been my first check but with the bing-bing working I assumed all was well in that department. Regards Alec.
Current Car
- x 5688
Yep, the discrete 'ding-ding-ding' is half the fun.
- x 8455
This is all terribly lost on us Xantia ownersmyglaren wrote:Yep, the discrete 'ding-ding-ding' is half the fun.
Pray, what is this ding-dong all about?
- x 5688
In the C5 estate there is a switch inside the tailgate that raises or lowers the rear of the car to make loading easier.
While it is being operated there is a constant 'ding-ding-ding' .
Only works with the engine stopped and the tailgate open, only operates on the rear suspension.
Fun to watch it return to normal when the tailgate is closed.
Not much practical use really.
Not on the hatches, more's the pity.
Saw my estate all fixed and ready to go last night
- x 8455
