Bit pricy, but if it works, I'd try it:
http://www.ebay.co.uk/itm/Dakota-Odour ... urn false;
Is this smell bomb any good?
Napoleon
- x 4
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
2009 HV09 C5 2.2
Tarte au Citroen
robert_e_smart
- x 14
Re: Is this smell bomb any good?
You are better cleaning the upholstery and removing the source of the odour, than hoping a new smell will stick on top of it.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
1991 BX 16 TGS Auto
Napoleon
- x 4
Farting's out of the question, then?
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
robert_e_smart
- x 14
Same effect as the odour bomb! It mightn't stick!
1991 BX 16 TGS Auto
1991 BX 16 TGS Auto
- x 1238
I found that carrying half a ton of eucalyptus logs in the back of the XM cured the doggy smell
addo
- Sara Watson's Stalker
- x 95
Risk with flatulence as a re-odorant, is the follow-through.
Tim, how much a handyperson do you fancy yourself? How is "Josephine" on the laundry front? I have successfully rehabilitated seats by skinning them of their covers - which were then double washed and lightly repaired - while the foams were sponged, treated with repeat poultices of bicarb and eventually hoovered clean. The real skill required is a little strength and deftness getting the covers off, and then some squeeze strength with the hog ring pliers to reinstall.
Napoleon
- x 4
We went out in the car yesterday and to be honest, no-one really complained, so maybe I've made too much of it. Not worth removing the covers, for sure. The other Xantia has a neutral kind of smell, so it does notice a bit in the estate.
I expect I'll sort of get used to it.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
Timmo
- x 168
Odour bombs typically have a 3 week longevity on the car and then your back to the old smells!
Most the smells are in the carpet from wet then dry wet then dry etc., b & q used to do a Decent carpet cleaning soloution for under a tenner for 5l and very dilutable, mixed in with some all purpose cleaner in a hot bucket of water and a scrubbing brush you can have nice clean smelling carpets in about half an hour,
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
SaabC5
Put some newspaper on top of where the spill/smell is coming from and then put some charcoal on the newspaper overnight. Lo and behold in the morning the charcoal will have absorbed the smell. (don't ask me how it works but it does)
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
Rhothgar
- (Donor 2026)
- x 225
Bleach works a treat!
Refreshes the design of your interior too.
Make sure you swirl it around when you're squeezing it out to give a nice swrily pattern though.
- x 8095
Now then RogerRhothgar wrote:Bleach works a treat!
