Xsara Picasso Air/Con Not working!
Post your Cit/Peu/Ren air conditioning queries or advice.
PicassoPigeon
Unread post by PicassoPigeon »
Light on dash comes on with a press of the button but no compressor turning and no fans running. Took car for re-gas but they have told me it is full of gas. Any ideas? Looks like all fuses in drivers side fuse compartment are all ok.
Is there another fuse to run the compressor?
Thanks for your help.
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
steelcityuk
Re: Xsara Picasso Air/Con Not working!
Unread post by steelcityuk »
Assuming that it's a straight forward setup, I'd check for power to the electric clutch mechanism. Then go from there.
Steve.
not applicable
addo
Sara Watson's Stalker
x 95
Unread post by addo »
If the cabin fan has died, you won't get the compressor to switch on.
Does the heater blower fan work with the AC off?
PicassoPigeon
Heater fan works fine(with a/c on or off), although is noisy when set on level 3 or 4. Like a rattling noise.
125,000 miles
PicassoPigeon
This is still rattling, it sort of increases with the revs and also as you go over speed bumps...but only when the fan is running. Anybody any idea?
125,000 miles
