Light on dash comes on with a press of the button but no compressor turning and no fans running. Took car for re-gas but they have told me it is full of gas. Any ideas? Looks like all fuses in drivers side fuse compartment are all ok.
Is there another fuse to run the compressor?
Thanks for your help.
Xsara Picasso Air/Con Not working!
Re: Xsara Picasso Air/Con Not working!
Assuming that it's a straight forward setup, I'd check for power to the electric clutch mechanism. Then go from there.
Steve.
Steve.
- Sara Watson's Stalker
- x 4
Heater fan works fine(with a/c on or off), although is noisy when set on level 3 or 4. Like a rattling noise.
This is still rattling, it sort of increases with the revs and also as you go over speed bumps...but only when the fan is running. Anybody any idea?
