Where to buy C5 spheres
martinwiseman2000
Unread post by martinwiseman2000 »
I need 2 front spheres for my 57 reg C5 HDi 2.0. For the last 25 years I've bought all my Citroen spares from GSF, however I've just been told they don't stock these.
Any suggestions as to where I should go other than a Citroen dealer?
Thanks,
Martin Wiseman
Citroenmad
x 110
Re: Where to buy C5 spheres
Unread post by Citroenmad »
You could try Wida Components, usually much better to ring them as not everything they can get hold of is on there. Or AEP Parts.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 2941
There are some on Ebay.
http://www.ebay.co.uk/sch/i.html?_from= ... Categories" onclick="window.open(this.href);return false;
If you want a gamble
Citroenmad
x 110
I would not be buying used sphres, they dont last forever and those ones will be getting down on gas now.
03 Seat Arosa 1.0S
x 1240
Unread post by Peter.N. »
There are some new ones on there:
http://www.ebay.co.uk/itm/CITROEN-C5-PA ... 254e191612" onclick="window.open(this.href);return false;
Jabo
Unread post by Jabo »
Just out of interest, how do you know you need new spheres? Did you get them pressure tested?
Only asking as my suspension isn't exactly right at the moment...
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
Citroenmad
x 110
You can pressure test them, or if you know what a good one should feel like its easy to compare if yours is more bouncy.
03 Seat Arosa 1.0S
Jabo
If this central Scotland meet happens then hopefully somebody can tell me if my spheres are ok.
For the year that I've owned the car the rear has sat lower than the front. Once in a while it will sit fine but it's mostly off.
Drive doesn't feel that smooth and for the majority of the time I get vibration through the steering wheel at speed.
Though the driver's side rear arm bearings need done...
Citroenmad wrote:You can pressure test them, or if you know what a good one should feel like its easy to compare if yours is more bouncy.
martinwiseman2000
Jabo wrote:Just out of interest, how do you know you need new spheres? Did you get them pressure tested?
I'm going on the feel, I'm definitely noticing bumps in the road more than I should and the car doesn't go down as far as I would expect when I push on the bumper, both of which are usually a sign that the spheres are on their way out. I know the C5 spheres are supposed to last longer than the type used on previous models, however the car has done 90,000 miles so it doesn't seem unreasonable to suspect them.
Citroenmad wrote:You could try Wida Components, usually much better to ring them as not everything they can get hold of is on there. Or AEP Parts.
Thanks for the suggestions, Wida couldn't help, however AEP had them in stock.
Martin.
Lighty
x 35
Unread post by Lighty »
I have changed a few C5 spheres, starting to get a few failed ones, usually one side fails.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
reblack68
Unread post by reblack68 »
Jabo wrote:If this central Scotland meet happens then hopefully somebody can tell me if my spheres are ok.
The rear arm bearings definitely make a big difference. I had one done last year and the other done this week and there was a marked improvement in ride on both occasions.
Richard
Care of a 1994 205 D.
