Citroen relay 2.2 2008 xlwb 122000 mile on the clock it starts runs but cuts out anywhere under about 2000 revs but then starts back up agian an the cycle continues????
It only does this when warm took it to my local citroen dealer they told me on the computer the cylinder ref signal is up injector 1,2,3 are showing, bsi fault, an rail pressure limiter.
Ive replaced the limiter but still doing it replaced fuel filter air filter put injector cleaner through her but alas stil the same result is there anything any one can tell me
Cheers
Richard
