Relay 2.2 2008 cutting out
hawkit12
New User
Unread post by hawkit12 »
Hi all i'm new to this forum just signed up thought it maybe an idea been as i have few relays an my family car is a c4 grand but i am after some guidence if anyone can help
Citroen relay 2.2 2008 xlwb 122000 mile on the clock it starts runs but cuts out anywhere under about 2000 revs but then starts back up agian an the cycle continues????
It only does this when warm took it to my local citroen dealer they told me on the computer the cylinder ref signal is up injector 1,2,3 are showing, bsi fault, an rail pressure limiter.
Ive replaced the limiter but still doing it replaced fuel filter air filter put injector cleaner through her but alas stil the same result is there anything any one can tell me
Cheers
Richard [-o<
Bick
x 43
Re: Relay 2.2 2008 cutting out
Unread post by Bick »
you need to get a leak off test done on the injectors - this can be done yourself with some pipes and plastic bottles. do a serch for leak off testing.
