C5 Crankshaft pulley
SaabC5
Can any Citroen boffins out there give me the torque setting for the dual mass crankshaft pulley on the 2.2 DW12TED4 please.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1056
Re: C5 Crankshaft pulley
pre tighten to 70Nm then 82 degrees +or- 5 degrees.
SaabC5
Thank you very much.
kenhall1202
Citroen DocBackup Repair Manual saysfor the DW12TED4 engine (under procedure B1EG1UP0 Removing - refitting : Timing belt : DW12TED4 TURBO DIESEL) :
"Coat the bolt (19) with LOCTITE FRENETANCH .
Fit :
Crankshaft pulley (21)
The tool [6]
The screw (19) with the washer (31), tighten to 4 ± 0,4 m.daN Finish with an angular tightening of 51° ± 5 °"
Tool [6] is the flywheel locking tool.
EDIT
For the later DW12TED4 FAP engine the following instruction applies:
"Coat the bolt (9) with LOCTITE FRENETANCH .
Fit :
The accessories drive pulley (10)
The bolt (9) with its washer
Tighten the screw (9) to 7 ± 0,7 m.daN Angular tightening A : 82 ± 3 ° " .
Take your pick! RP number would help to clarify.
Fit :
The tool [6]
EDIT
Fit :
Ken Hall
- x 1056
Never seen a 2.2HDi C5 without FAP...
I normally torque them to FT with an air gun
