Xantia-Wipers & Scuttle
x 7163
Hello
....oooooh...........this sounds like question which I should know the answer to already. After all-I took them off in the first place... but here goes
Anyone know which way round the wiper arms go?
and a supplementary if I can
The plastic scuttle (I think this is the right term for it) mine is in 2-bits is this normal?
I had a windscreen replaced and the scuttle was not resealed and just butting up against the screen. It appears there was a originally a rubber sealing strip. Its US now and I am in the process of scraping the remains off.
On reinstalling the scuttle is a bit of bathroom silicone the type of thing required to seal the scuttle/screen?
Kind regards
robert_e_smart
x 14
Re: Xantia-Wipers & Scuttle
Unread post by robert_e_smart »
Hi Neil,
The scuttle should be one piece. Don't use bathroom, sealant, its crap. Use proper windscreen sealant or instant gasket to reseal the scuttle trim. If you want a good replacement one, I have one here spare.
The wipers as positioned in your second picture are correct for re-assembly, the longer arm before pivot goes to the drivers side.
Robert
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
x 7163
Robert
I had it just 100% wrong. Thanks for letting me know you have a good complete one available but for now I think I will just use the old one and seal it up with some decent sealant. Is a duff windscreen scuttle seal one of the reasons for a soggy footwell?
x 8290
Absolutely Neil, if the scuttle is cracked and not properly bonded to the base of the windscreen then rainwater will simply pour in through the air intake and straight under the passenger footwell carpet.
Only one way to dry it out and that's to have the carpets and underlay foam out. That means having the seats and centre console out :(
Robert's right. Only use quality automotive grade silicone RTV sealant on the scuttle panel.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You could also use a glazing polyurethane such as sold by Sika. The biggest gain here, is no acid release upon curing.
x 7163
Thanks everyone
Looked up RTV sealant (Room Temperature Vulcanising apparently)
Is this the type of stuff that will do.......Granville Silicone Sealant Clear from Halfords
x 8290
Yep, that'll do Neil. Just be sure to really thoroughly clean the windscreen edge and the scuttle edge to ensure a good bond.
Also, be very careful not to get any silicone on the area of the screen where the wipers sweep. It'll cause the most terrible smearing next time it rains and it's a devil to remove.
addo
x 95
The sealant tricks there, are to set a pair of tape strips - one either side of the joint and immediately upon tooling off the silicone to remove the tape. it is important to tool the silicon hard enough (tight fillet radius) such that there is bugger-all left on the tape. If the sealant skins or cures while the tape is in place, you've lost the contest.
By comparison, tape finishes for polyurethane are removed once it's decisively skinned.
robert_e_smart
x 14
I use a knife blade to scrap back any excess sealant from the glass. Works fine if you can be bothered and have the patience.
1991 BX 16 TGS Auto
x 7163
Here is the missing scuttle, and the air intake
add a soggy Northumberland Sunday
Here is the puddle in the footwell
VertVega
x 13
Unread post by VertVega »
It seems that it has been raining cats & dogs :)
Heater blower must also be soaked totally. It's worth checking if there are other
places from where rain water got in. Start with lifting rear seats. Are they wet?
If it's an Estate then check under the trunk carpet also.
About the wipers, driver's side has shorter arm & longer blade 8-)
introfusion123
Unread post by introfusion123 »
Haw you take down plastic trim ?
x 7163
introfusion123 wrote: 06 Jan 2020, 16:19 Haw you take down plastic trim ?
The car, the scuttle, the wipers, and the puddle in the footwell have long gone now, nearly 8 years ago now,
but nice to know the old threads still get read :-D
x 1438
Unread post by xantia_v6 »
The scuttle trim is stuck to the windscreen by a rubber strip or silicone sealant. You must cut this away carefully with a sharp knife. If you pull too hard, you will break the scuttle trim, or even the windscreen.
introfusion123
xantia_v6 wrote: 06 Jan 2020, 20:11 The scuttle trim is stuck to the windscreen by a rubber strip or silicone sealant. You must cut this away carefully with a sharp knife. If you pull too hard, you will break the scuttle trim, or even the windscreen.
Thx Man ,, it's silicon seal
