Happens when going to pull off sort of a second delay before anything happens. The accelerator cable seems to have no slack, fully serviced, egr3 cleaner used only use shell fuel.
Car is all standard and elloys fluid and filter all seem fine.
flat spot when pulling off any ideas?
- waynedance
- x 8
Volvo S80 D5.........
- waynedance
- x 8
Re: flat spot when pulling off any ideas?
No ideas anyone?
If I give plenty of gas and let clutch out slowly the power is there.
EGR slightly stuck is a fair possibility, otherwise maybe a small boost leak, does it make any hissing noises under acceleration?
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- waynedance
- x 8
not noticed any noises, how can I check the egr?
- x 9
Check swirl valves are fully closed (arm rearward) if these are open low end performance is crap. Bearing in mind that these need vacuum to close it may be you have a leak and there is not enough vacuum to close them at idle and they only close when the engine gets a few more revs and the vac pump is working a bit harder.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- My Cars: C5:Hatch & an Esatate. Real cruisemobiles.
Had this happen too. Turned out to be the swirl valves as mentioned by Cachaciero - the actuator arm end ( Ball joint ) had broken in my case. I just cable tied the lever back to closed position and all was ok. It's still cable tied now.......
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
- waynedance
- x 8
swirl valve thing works moves at approx 2100 revs, had a new ball arm on last year.
- x 9
Lexia time, although there are apparently no faults a Lexia would allow monitoring of critical items such as turbo pressure, fuel pressure etc.
cachaciero
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- waynedance
- x 8
I have no lexia but have used a launch diagnostic and no codes present.
- waynedance
- x 8
It is that size and does have a lot of information. like how many regenerations been done and such.
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
In that case, you should be able to do what Cachaciero suggests, driving around with the screen aimed to see what's going on at varying combinations of load and pedal position on a warm engine. If numbers are too hard to read, there may be a graph option to show any selected characteristic against real time (a bit like an oscilloscope).
The Launch tool isn't bad on Fiat family cars.
