flat spot when pulling off any ideas?
waynedance
x 8
Unread post by waynedance »
Happens when going to pull off sort of a second delay before anything happens. The accelerator cable seems to have no slack, fully serviced, egr3 cleaner used only use shell fuel.
Car is all standard and elloys fluid and filter all seem fine.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
waynedance
x 8
Re: flat spot when pulling off any ideas?
No ideas anyone?
If I give plenty of gas and let clutch out slowly the power is there.
Lighty
x 34
Unread post by Lighty »
EGR slightly stuck is a fair possibility, otherwise maybe a small boost leak, does it make any hissing noises under acceleration?
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
waynedance
x 8
not noticed any noises, how can I check the egr?
cachaciero
x 9
Unread post by cachaciero »
Check swirl valves are fully closed (arm rearward) if these are open low end performance is crap. Bearing in mind that these need vacuum to close it may be you have a leak and there is not enough vacuum to close them at idle and they only close when the engine gets a few more revs and the vac pump is working a bit harder.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
Had this happen too. Turned out to be the swirl valves as mentioned by Cachaciero - the actuator arm end ( Ball joint ) had broken in my case. I just cable tied the lever back to closed position and all was ok. It's still cable tied now.......
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
waynedance
x 8
swirl valve thing works moves at approx 2100 revs, had a new ball arm on last year.
cachaciero
x 9
Lexia time, although there are apparently no faults a Lexia would allow monitoring of critical items such as turbo pressure, fuel pressure etc.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
waynedance
x 8
I have no lexia but have used a launch diagnostic and no codes present.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It's the running parameters/data you want to be looking at there. I don't know how good the Launch would be for that - possibly some use, if it's the MacBook sized unit.
waynedance
x 8
It is that size and does have a lot of information. like how many regenerations been done and such.
addo
x 95
In that case, you should be able to do what Cachaciero suggests, driving around with the screen aimed to see what's going on at varying combinations of load and pedal position on a warm engine. If numbers are too hard to read, there may be a graph option to show any selected characteristic against real time (a bit like an oscilloscope).
The Launch tool isn't bad on Fiat family cars.
