Scenic front subframe
centurus2400
x 4
Unread post by centurus2400 »
A friend of mine has a 2005 Scenic diesel with about 85k on the clock from new.
It failed it's MOT last week on a list of items, the main ones being excessive play in a front subframe mounting bush/pin, and worn rear trailing arm bearings.
The garage say that the subframe bushes aren't available separately as replacement items, and the whole front subframe will have to be renewed at a cost of over £600 for the part alone.
I'm a bit :shock: at this, and wondered if they're trying to pull a fast one or if this in in fact the case?
I haven't heard what she's' been told about the trailing arm bushes, I assume they can be replaced...
lexi
x 133
Re: Scenic front subframe
Unread post by lexi »
I don't know but you can drop in to Renault dealer and ask if the bush comes separate. Friendly one will you a copy of the drawing.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
