Gutted!!! Clipped my sump on a rock in a car park on Dartmoor, holed the sump and seconds after the oil light came on the camshaft had seized/snapped. The bottom end turns, the top end doesn't!
Getting the car taken home to Nottingham (it's still near Plymouth at the mo) and will be deciding what to do with it.
It's a really smart car but I guess it's dead now?
Has anyone got a cheap diesel Xantia for sale near to Nottingham?
Need to drive back to work on Monday morning. I'm in the Navy so HAVE to get back.
Can anyone help????
Kind regards,
Steve.
Killed my new 1.9TD Xantia!!!!
Stepto1
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
KP
- x 27
Re: Killed my new 1.9TD Xantia!!!!
Thats really bad luck
I cracked the sump one my 1.9td but it took ages for the bottom end to start rattling and the engine still ran half decently even then...
Have you thought about getting a 2nd hand head shipped to you and just getting it popped in quickly with some new belts and fluids?
- x 94
would be easier and quiker to drop another complete lump in if you can find a known good one localish,
regards malcolm
regards malcolm
Stepto1
Wouldn't the bottom end be damaged now?
Not sure the cost of a head, belt and fluids would be worth it.
Need to get it all sorted over the weekend.
So cross!!!!
So cross!!!!
HDI
- x 7
If the bottom end isn't knocking the bearing shells could still be damaged. You might be lucky and get away with it but to be certain it isn't going to let you down they need checking. To do that and replace the head is going to take quite some hours though, and it isn't guaranteed all will be ok straight away.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Lighty
- x 35
I have a Xantia estate, but in its current estate, I want £800 for it, not really what you would call cheap, it will be more when I have finished fettling it. Its a Mk11 1.9td with a genuine 98K , new mot and taxed till Nov.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Stepto1
Thanks mate but a bit out of my budget. Just missed a 2.0HDI for 300 quid!
addo
- Sara Watson's Stalker
- x 95
Citroenmad
- x 110
That is bad luck!
For the cost of buying a another car you could get a secondhand engine and have it fitted.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
mendedit
The world is full of them and a lot are in
Stepto1
Cheers guys. Decided to just get another motor and have a look at the bottom end if this one when I have some time.
Found a tidy black 2.0HDI that just needs a starter motor. £300 quid sound ok? It's done 140k miles.
Anything to look for on the HDI?
Wish me better luck with this one!
- x 8365
That's a bargain for an HDi..
Look for all the usual Xantia foibles really. The engine is generally pretty bombproof but do check all the normal dieselly things...
Is it a 90 or a 110?
On a 110 do check cooling, condition of the turbo hoses and engine mounts as a first thing... The lift pump in the tank can fail but apart from that if it runs then it'll be a good buy...
Harlequin
- x 24
- x 8365
And at 140K it's barely run in...
Rhothgar
- (Donor 2026)
- x 221
Steve needs his to be rockproof, Jim!CitroJim wrote:The engine is generally pretty bombproof
Seriously though, are you looking to strip the Xant S1 or are you going to repair it in the long term at some point?
