Yup, that's what my 2004 Picasso 2.0HDi (Bosch system) made on the rollers at work t'other day. I popped it in as I suspected it wasn't running at full power, and I was right.
At lower revs it feels fine and drives as I'd expect (although I've never driven any others). But after 1500rpm, or about 40% throttle opening it just goes flat. It does still pickup, but really really lazily. You can here the turbo spooling and there are no fault codes other than EGR valve (which I'll get on to in a mo) and sometimes a glowplug timer unit pops up. You need to bury the throttle to get up hills on the motorway!
So far I have ruled out:
Brake switch - I thought it was a bit of a (very) long shot but somes on the Picasso site suggested it.
Throttle cable tension - likewise the above.
EGR valve - I blanked it off tonight. Runs a bit smoother and generally feels happier, but the original problem is still there.
I've cleaned the MAF. It looked fine, but I know this could be an outside contender.
Air filter isn't blocked.
Turbo wastegate actuating rod does move so not seized. It's spring loaded but moves smoothly around 1-1.5cm.
Turbo boost pipes appear to inflate as engine is revved (though not by much).
No apparent boost leaks. Turbo spools up nicely, but admittedly does get a bit whooshy after 2k revs, rather than the whistle it initially pipes up with.
I'd like to measure the boost to see what it's pushing out. Any ideas? Fitting a boost gauge looks trickier than it did in my Activa all those years ago!
Cheers
55bhp Picasso 2.0 HDi
Lighty
- x 35
Re: 55bhp Picasso 2.0 HDi
Think I would try another Maf
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
kitchD6C
- x 4
Just found another post about the same thing. No fault codes though, and never have been. Do they always show up?
Lighty
- x 35
poor maf performance doesnt
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 5648
Me too. I cleaned mine, made no difference but a new MAF certainly did.Lighty wrote:Think I would try another Maf
Try and borrow a known good one for comparison before buying.
- x 8281
Yep, I'd say MAF too. Easily tested with a Lexia. See about 500 units of airflow at idle quickly rising to about 700 - 800 as you open the throttle. You may see the output staying nearly constant throughout the rev range with a poor MAF...
HDI
- x 7
MAP sensor ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Citroenmad
- x 110
55bhp, impressive!
Id go with the MAF too, they dont often/usually bring up a fault code in my experience.
However one I replaced was with a cheap one and that was no better. After fitting a genuine one the car was transformed.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
steelcityuk
Apparently loads of fakes on the market so buy from a main dealer. Was the gas mileage good on 55bhp?
Steve.
Steve.
not applicable
kitchD6C
- x 4
Maybe MAF is the next route then. Ideally I'd find one I can try first to confirm it, as I know they're only £35 on eBay but the last cheap one I bought online didn't work all that well!
Economy isn't too badly affected at lower speeds, as the issue only becomes an issue when you need more speed. If you do a motorway trip it's mid 30's though, because you're nearly flat out everywhere.
Lighty
- x 35
Expect to pay over £60 for one that works
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Chris570
- x 36
i bought a genuine one from gsf, was about 30 quid cheaper than the main dealers
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
kitchD6C
- x 4
New MAF picked up from local factors and fitted - car has noticably improved
Going to dyno it later to see just how much, but overall the MAF has made a massive difference.
Timmo
- x 168
is that kitch from bx16v??
hadnt twigged the name and using rollers at work etc.!! if so, Hello matey! *waves*
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
kitchD6C
- x 4
Hello mate
83.5bhp. I'll call that a win. It's still p**s-poor slow, but at least it's as slow as it's supposed to be!
