Lexia
Stekelly
Lexia
Unread post by Stekelly »
Just having my first go connecting the Lexia to my SII . When I connect it the software is telling me to connect the AL04 cable. So what exactly am I conecting up to get the lexia to read the Xantia? Cheers.
Presumably I have all the necessary cable, have everythign below.
robert_e_smart
x 14
Re: Lexia
Unread post by robert_e_smart »
Ohhhhh, I didn't know you had a Lexia Ste.
I have a 2.5 XM that is misbehaving if you run out of cars to play with it on!
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
DickieG
Monaco's youngest playboy
x 33
Re: Lexia
Unread post by DickieG »
The AL04 cable is normally requested when using a genuine Lexia but anyway it refers to a charging cable for whatever computer the Lexia is running on, if your laptop has sufficient power then ignore the instruction.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Stekelly
Re: Lexia
Cool cheers.
Only got it last week Rob. It's available whenever needed.
Have been using it on the C8. Everything on the lexia seems to work as it should.
robert_e_smart
x 14
Re: Lexia
Excellent! I may have to pop down with said 2.5 some time. Its starting to annoy me now.
1991 BX 16 TGS Auto
Stekelly
Re: Lexia
Only got back to connecting it bak up again yesterday. First thing I noticed is that there seems to be a lot less available info than when I hooked it up to the C8.
I have an ABS issue, that much is certain. But should I be able to see what sensor etc is at fault through the Lexia? The only thing I can see is in the stored fault codes that shows a wheel speed error, but no which wheel/sensor. The stored fault says it came up at 68km/h. I can get the live data for the wheels and but the car is currently off the road so cant go on a test drive to see.
Should I be able to see a similar amount of data to what I could on the C8?
x 8457
Re: Lexia
The ABS stored faults tell which sensor it is by which wheel speed is wrong - normally It uses the LH and RH convention, RH being the driver's side in the UK on an RHD car...
Granularity of data is very much dependant on the age of the car. newer ones gives far more as technology improved. Newer cars also read a lot faster too...
VertVega
x 13
Re: Lexia
Unread post by VertVega »
Stekelly wrote:... Presumably I have all the necessary cable, have everythign below. ...
Yes, you've got all the necessary cables :) Even the ones that you don't need.
Slightly off topic :wink: I have Lexia installed in XP and works fine but I wonder if it works with Windows 7 ?
Any experience, anybody?
x 8457
Re: Lexia
VertVega wrote: Slightly off topic :wink: I have Lexia installed in XP and works fine but I wonder if it works with Windows 7 ?
I don't believe it will as Windows 7 (and Vista :evil: ) are written on very different codebases to XP.
Anyway, there would be nil advantage in doing so. XP is perfect for the job.
VertVega
x 13
Re: Lexia
Thanks CitroJim, it's good to know 8-)
Stekelly
Re: Lexia
CitroJim wrote:The ABS stored faults tell which sensor it is by which wheel speed is wrong - normally It uses the LH and RH convention, RH being the driver's side in the UK on an RHD car...
I saved it so I'll get the laptop out of the car in a bit so I can get the exact wording.
It's my SII 2000 reg 1.8 so I would have thought it would give me as much data as I can get from a Xantia.
