Fluid gathering
KennyW
x 165
Fluid gathering
Unread post by KennyW »
Hi All,
I've noticed fluid gathering at the injectors on my Xantia so I removed it. It has appeared again.
3 injectors appear 'damp' at the base going into the head
Is it a small diesel leak :?:
I'll take a photo and post it.
Kenny
C3 1.4 petrol (SWMBO)
Xaccers
x 188
Re: Fluid gathering
Unread post by Xaccers »
Leak off pipes, er, leaking?
DIY sphere tool
KennyW
x 165
Re: Fluid gathering
Thanks Xac,
Ooooops forgot to check them :oops:
Kenny
Xaccers
x 188
Re: Fluid gathering
I had the same thing with Cassy leaking SVO and pooling around the gearbox end injector, when the engine was hot it would bubble like oil in a frying pan :D
DIY sphere tool
Old-Guy
x 24
Re: Fluid gathering
Unread post by Old-Guy »
Xac wrote:I had the same thing with Cassy leaking SVO and pooling around the gearbox end injector, when the engine was hot it would bubble like oil in a frying pan :D
Surely that's because it was?
Xaccers
x 188
Re: Fluid gathering
Indeed, I cracked open some eggs, threw on some bacon and had a lovely breakfast :D
DIY sphere tool
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Bacon! :shock: I hope not...
x 5673
Re: Fluid gathering
addo
x 95
Apply those descriptive zones to a silhouette of Emmanuelle Béart, and we might agree!
KennyW
x 165
Re: Fluid gathering
I've checked the leak off pipes and it is not from there.
I suspect the copper seals which seals the injectors into the head as there are signs of fluid there. 3 out of the 4 injectors are showing signs of fluid possibly leaking from this point.
Any other thoughts except bacon :!:
Kenny
x 8378
Re: Fluid gathering
KennyW wrote: Any other thoughts except bacon :!:
Kenny
Eggs, toast, fried tomatoes, mushrooms and hash browns :-D Kenny, seriously, I have noted that practically every HDi I've looked at shows little pools of oil around the injectors and I think you're right, the copper washers need replacing. Personally, unless it's looking very wet down there I then I'd not worry too much.
Mine has little pools and I'm not overly concerned about it...
Xaccers
x 188
Re:
addo wrote:Bacon! :shock: I hope not...
I'd do beef, turkey or quorn bacon for you Addo, and make sure it's cooked up the other end of the engine to avoid contamination :)
DIY sphere tool
HDI
x 7
Re: Fluid gathering
Unread post by HDI »
Another possible cause for fluid around the injector bases is a leaking oil filler cap gasket and or cam cover gasket. I had the oil cap issue on mine, the gasket isn't available separately, it's a new cap only.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 8378
Re: Fluid gathering
HDI wrote:Another possible cause for fluid around the injector bases is a leaking oil filler cap gasket and or cam cover gasket. I had the oil cap issue on mine, the gasket isn't available separately, it's a new cap only.
Good thinking :-D I had exactly this on mine and replaced it without a second thought as it was loose in the cam cover. The rubber seal went all gooey. New caps are very cheap - about six quid if I recall...
x 94
Re: Fluid gathering
Unread post by citronut »
CitroJim wrote: about six quid if I recall...
sick squid?? we have them in our local sea life centre :shock: :roll: :lol: :wink:
regards malcolm
