Buggered my C5 2.0 HDI UP
garrydog
My car is a non runner and it is my stupid fault,PUTTING NASTY FUEL IN IT.Long story but i am trying to sort it out ,I have come to the conclusion with some help that i have some or all of my injectors blocked.I have empted and cleaned the fuel tank and the fillter below the pump,i have cleaned and renewed the fuel fillter and flushed all of the fuel lines from the tank to the fuel fillter.All the electronics and fuel presures are as they should be.
I have had a price from a guy to change the injectors of £650
Another outfit said that the high presure pump would be contaminated and would need to be changed at £780 just for the parts .
Now for my idea ,I can buy a full set of injectors from the scapper for £55 ,I can put these in and see if they get blocked if they don't then i will have my own cleaned at reasonable cost.I have changed injectors on Pugs 405 306 before,is there anything that i should know before i start this job.
The best way to get this type of injector out?
Where is the best place to buy the new seals ect that i may need. Any help would be great .
My car is Citroen C5 2.0L hdi 54 plate just over 30,000miles.
Thanks.
Thanks.
2004 C5 VTR 2.0L HDI hatchback.
dnsey
- x 19
Re: Buggered my C5 2.0 HDI UP
I believe that the injectors have to be matched to the ECU via Lexia in order to calibrate the system and make it work properly.
citroenxm
- Fallen Hero
- x 70
NO The injectors do not really need matching! Get a Pump for around £100 quid, and a set of injectors.. They are NOT hard to change at all!
The injectors are a push fit in place secured by a clamp with a single 13mm nut... AFTER the fuel pipes have been moved.
Engine fuel pumps do NOT need timing... Those prices from your mechanic seem rather excessive to me in a big way!
I say the injectors dont need matching from experiance! I took a Xsara HDi 90 engine at 103k, fitted a 110 inlet manifold and Turbo to it, and stuck it straight into a Xantia.... The ECU never said a word, and that was a 90 pump and injectors...
Car now on 272k and sounds well.... Ive also messed with injectors on my own 110 Xantia due to injector tick and never needed a Lexia to do anything...
As long as the Pump is from a 2.o 8v OR a 2.2 16v Early engine, it will be fine, and the injectors from a 110 8v too..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
garrydog
Thanks very much citoenxm ,thats the best news i have had all day cheered me up no end. But do i need to change the pump, if i can flush the pump with fresh diesel will it not be OK?
- x 8254
What exactly was the nasty fuel you put through it?
citroenxm
- Fallen Hero
- x 70
Ooerrr sorry.. I thought after your quotes it was good news...garrydog wrote:Thanks very much citoenxm ,thats the best news i have had all day cheered me up no end. But do i need to change the pump, if i can flush the pump with fresh diesel will it not be OK?
As per jim.. What exactley have you put through her???
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
cachaciero
- x 9
Injector matching is not essential to get a running engine, however the ECU does need to know what class of injectors are fitted for optimal performance and I suspect to make the onboard computer consumption correct.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
garrydog
The fuel was given to me ,it had been stored for a good while years, 10 galls. On removal from the tank with a small pump the fillter on the pump was full of a waxy substance this was also suspended in the fuel ,the fuel fillter in the tank was full of it so was the fuel fillter in the engine bay.
- x 8254
Oh gosh, when diesel goes off it really goes off
I've seen what stagnant diesel does to pumps where it's been hanging around them for years and it's not nice...
Basically it covers the surfaces in a hard varnish which can be very difficult to remove and deposits little bits all over the place as well as gumming things up...
This is a picture of a Bosh VP20 (as fitted to the 1.9TD engine) that had been standing a few years full of diesel:
This is the components of the lift pump. It looks like rust in the picture but isn't...
No wonder your injectors might have thrown in the towel! Hopefully the HP pump will BE Ok after some clean diesel has flushed through it. If new injectors gets the engine running then dose up the fuel in the tank with double or even triple strength diesel treatment - that'll help clean everything up...
Good luck!
Good luck!
garrydog
Thanks for all of your help brilliant! Just removed the injectors no problem,waiting for the replacements to come in the post then see if the engine will run.
A guy will clean and test my original injectors for £200 is this price OK?
garrydog
Problem solved put the second hand injectors in this morning ,car is running now OK .
Thanks to you all David .
- x 8254
citroenxm
- Fallen Hero
- x 70
Great.. Be interesting to see what state exactly the injectors are in...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
garrydog
The car is running better than ever, I am going to leave the second hand injectors in the engine for now.
David.
David.
citroenxm
- Fallen Hero
- x 70
...And you simply put them in and went??? No lexia needed???
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
