de-catting c5?
sonoramicommando
x 5
de-catting c5?
Unread post by sonoramicommando »
Can I de-cat c5 without causing some sort of ECU to freak out?
By that I mean, either cut and replace with a test pipe (i suppose x2 test pipes for each bank) or smash out the innard.
Cheers,
Sam
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
x 1942
Unread post by Paul-R »
If it were a diesel then yes but I think you might have problems with the Lambda probe signals in a three way cat on a petrol engine.
sonoramicommando
x 5
Drag - it's a v6 petrol.
I haven't checked the price but it's bound to be pricey (times 2).
I suppose there are two oxygen sensors, one upstream and one down stream?
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Three, possibly - if it has light-off cats for each bank.
den169
Unread post by den169 »
I think starting sometime next year any car that should have a cat and hasn't will fail the mot.At least thats what my mot tester son in law to be told me.
sonoramicommando
x 5
What's a "light-off cat"?
On Citroen Service for my VIN, it shows there are two oxygen sensors per bank - which must mean that ECU will compare the some numbers pre & post cat. And it's bound to kick up a fuss if both numbers are the same with a gutted cat.
den169 - Do you mean no cat = MOT fail or no "functioning" cat = fail? If its the former, gutting the cat (provided it doesn't cause ECU problems) is the way to go.
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
addo
x 95
By light-off cat, I mean the smallish converters that are on some cars, immediately after the bank's collector manifold:
