Can I de-cat c5 without causing some sort of ECU to freak out?
By that I mean, either cut and replace with a test pipe (i suppose x2 test pipes for each bank) or smash out the innard.
Cheers,
Sam
de-catting c5?
sonoramicommando
- x 5
de-catting c5?
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
- x 1909
If it were a diesel then yes but I think you might have problems with the Lambda probe signals in a three way cat on a petrol engine.
sonoramicommando
- x 5
addo
- Sara Watson's Stalker
- x 95
den169
sonoramicommando
- x 5
What's a "light-off cat"?
On Citroen Service for my VIN, it shows there are two oxygen sensors per bank - which must mean that ECU will compare the some numbers pre & post cat. And it's bound to kick up a fuss if both numbers are the same with a gutted cat.
den169 - Do you mean no cat = MOT fail or no "functioning" cat = fail? If its the former, gutting the cat (provided it doesn't cause ECU problems) is the way to go.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
addo
- x 95
