Xantia sidelights
froggy
(Donor 2026)
x 4
Xantia sidelights
Unread post by froggy »
Hi, can ayone tell me what spec the sidelight bulbs should be in my Xantia [ s1] I"ve got one really bright bulb and one really dim. cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1484
Unread post by xantia_v6 »
They should both be bright :wink:
x 1240
Unread post by Peter.N. »
They are normally 5 watt.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
If you remove the dim bulb it'll more than likely be blackened.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Xantidote
x 4
Unread post by Xantidote »
5 watt, capless (ie. it just pushes into the holder). You have to twist the holder a bit to remove it from the headlamp unit - dexterous fingers useful here!
As DickieG says, maybe a blackened bulb, in which case soon to give up the ghost. Could also be a bit of corrosion in the multi-plug/socket at the back of the headlamp. I'd go for simply replacing the bulb.
Martin
1995 Xantia TDLX (deceased :( )
