Xantia boot light.
citroenesque
x 4
Xantia boot light.
Unread post by citroenesque »
Wasn't working, so changed the bulb. Still not working. Next step, - boot open switch - but where is it? Or could it be a fuse... in which case, again, where/which?
(Late S1 car saloon).
1997 Citroen Saxo SX 1.6i Auto, Fijian blue, 60k mls
2004 Citroen C5 Exclusive SE 3.0 V6 Auto. Silver. 114k mls
2006 Citroen Xsara Picasso Desire 1.6 16v, Sahara bivouac (beige). 128k mls
2008 Citroen C1 Vibe, red. 74k mls
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The switch is a mercury tilt switch located behind the black plastic trim, look for a white plastic tube with a wire running to it, roughly in the middle.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8457
Hi Phil,
Under the trim panel near the wiper motor. It looks like a little white tube with a curved end and one spade terminal on the other end.
It has a ball bearing inside that makes a contact to earth when the boot is open.
In effect it's a tilt switch.
It can be carefully opened and its ball and contacts cleaned up but it's not often 100% long-lasting...
A stealer should be able to supply a new one...
From my old electronics days I always think it looks a bit like a white OC71 transistor!
x 8457
Sorry Richard :oops: Me and thee typing at the same time....
x 8457
Just remembered, it has two balls inside it.. A big one and a little one....
Thankfully no mercury Richard. If it had mercury in it then it would be 100% reliable....
citroenesque
x 4
Thanks will have a look tomorrow...
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
Could it be a break in the wiring loom, but my revearsing lights and top brake light were not working either on my estate.
