Wasn't working, so changed the bulb. Still not working. Next step, - boot open switch - but where is it? Or could it be a fuse... in which case, again, where/which?
(Late S1 car saloon).
Xantia boot light.
citroenesque
- x 4
Xantia boot light.
1997 Citroen Saxo SX 1.6i Auto, Fijian blue, 60k mls
2004 Citroen C5 Exclusive SE 3.0 V6 Auto. Silver. 114k mls
2006 Citroen Xsara Picasso Desire 1.6 16v, Sahara bivouac (beige). 128k mls
2008 Citroen C1 Vibe, red. 74k mls
DickieG
- Monaco's youngest playboy
- x 33
The switch is a mercury tilt switch located behind the black plastic trim, look for a white plastic tube with a wire running to it, roughly in the middle.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8406
Hi Phil,
Under the trim panel near the wiper motor. It looks like a little white tube with a curved end and one spade terminal on the other end.
It has a ball bearing inside that makes a contact to earth when the boot is open.
In effect it's a tilt switch.
It can be carefully opened and its ball and contacts cleaned up but it's not often 100% long-lasting...
A stealer should be able to supply a new one...
From my old electronics days I always think it looks a bit like a white OC71 transistor!
- x 8406
- x 8406
citroenesque
- x 4
wotwot
- (Donor 2021)
- x 4
