Xsara hdi 2001 Cutting Out
CraigLee1971
Hi
Ive got a 2001 hdi xsara if I take it up the road 100yrd it cuts out and wont start up again leave 5 10 mins and it starts it will tick over and rev up on drive but once theres load it cuts out what can it be
I can here pump in tank priming
- x 5658
- x 5658
Sorry, it was unclear but I meant the filter.
Have you checked for air ingress - if there is clear piping between the filter and the diesel pump you may be able to see bubbles in the fuel while it is idling. If there is you will need to check the fuel lines and leakof pipes for leaks.
In fact, check the leakoff pipes first, for hardening and cracking, also the terminating cap could have come off.
- x 5658
CraigLee1971
CraigLee1971
what I have doe so fare is replace the preasure regulator on the pump and preasure sensor on on the rail car will tick over and rev up on drive soon as you go 100 yards up the road it will cut out leave car 5 to 10 mins and it will start could i have crank sensor problem brown relay be replaced as well mod to air flow meter to make better earth and still cuts out under load
CraigLee1971
- x 5658
ebod
CraigLee1971
DickieG
- Monaco's youngest playboy
- x 38
As I understand it when HDi's have a problem on the fuel high pressure side they run on slightly after being turned off.
The best way of sorting this out will be getting a diagnostic check done, are you near anyone on the Lexia list?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
