Fusebox
superloopy
x 19
Fusebox
Unread post by superloopy »
Has anyone any tips on removing / replacing the under bonnet fusebox?
My S2 activa has immobiliser problems and this fusebox has been identified as a potential cause of the problem followed by a wiring issue.
Had a quick look today and need a LOT more info before i go there :?
Anyone able to help?
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
IIRC its held in by a few nuts locating on studs on the inner wing, I think you have to remove/loosen things either side of the box to see them. Rather than remove the whole fusebox can you not simply replace the relevant fuses or relays individually, there is normally a fair bit of room in there for doing such modifications. The relay plate simply clips in.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It's a right mongrel!
Battery out first for better access; the fusebox hold downs are 10mm nuts well hidden. IIRC you need to disconnect the three black infeed wires, too.
superloopy
x 19
You're right :evil:
I can only 'see' one fixing bolt, now removed. The others appear to be behind the small 15way fusebox on the right as you look at the engine bay.
How does this lift out? Its got a couple of small lugs which seem to do nothing.
When (if) i eventually manage to get this out of the way what am i letting myself in for when it comes to the feed wires. How do they 'attach' to the fusebox itself?
Replacement fusebox on order so i've got a bit of time, thanks!
Mike
KennyW
x 163
Unread post by KennyW »
Mike,
It is a pig of a job patience is required :evil: but it can be done.
Kenny
C3 1.4 petrol (SWMBO)
superloopy
x 19
KennyW wrote:Mike,
Kenny
But, how?
How do i 'lift' the small 15way box in order to acces the bolts, which sem to go into the inner wing ...
Mike
addo
x 95
There are three infeeds from memory, all black - they bolt on with different size/shape eyelets so crossbreeding requires a fair degree of persistent stupidity.
Dippy
Unread post by Dippy »
addo wrote: fair degree of persistent stupidity.
:D My Headmaster wrote that on my leaving report 40 - yrs anon.
He also mentioned being unable to educate Pork ....
superloopy
x 19
addo wrote:There are three infeeds from memory, all black - they bolt on with different size/shape eyelets so crossbreeding requires a fair degree of persistent stupidity.
How are the harness feeds attached?
Mike
addo
x 95
Flanged nuts; two M10 one M13 from memory.
If you don't mean the main 12V supply, the others I am not sure about! They may be soldered into the back of the fuse board. I wangled everything up and out the way to replace my 12V feeds.
superloopy
x 19
addo wrote:Flanged nuts; two M10 one M13 from memory.
Not the 12v feeds, i've managed them recently when i swapped over the '+' battery lead.
I mean, how are the harness inputs attached at the back of the fusebox, surely they're not soldered in as that would make replacement of the box impractical. Are they clipped in? If i could release the small fusebox from its mounting box i'd be able to tell you myself :x
Mike
DickieG
x 38
Normally the connectors are attached to the sockets by way of little one way tags that need to be depressed as the connector is pulled out, I use a very small flat blade screwdriver to do this.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
superloopy
x 19
DickieG wrote:Normally the connectors are attached to the sockets by way of little one way tags that need to be depressed as the connector is pulled out, I use a very small flat blade screwdriver to do this.
Richard, thanks!
Any idea how to lift out the small fusebox to get at those inner wing bolts?
Mike
DickieG
x 38
superloopy1 wrote:Any idea how to lift out the small fusebox to get at those inner wing bolts?
When it stops raining (understatement) I'll have a look to remind myself.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
lexi
x 134
Unread post by lexi »
Wondered if your inbox was full Mike ?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
