AX spark plug gap
scratcher
x 3
AX spark plug gap
Unread post by scratcher »
Hi, I am 'lumbered' with getting my grandsons AX ready for MOT. What is the correct spark plug gap for a just under 1000cc engine? The BOL says it is at the beginning of the relavent chapter-rubbish and the Citroen manuel says that this an important measurement for the efficient running of the car but does not state what it should be. If all else fails I will set it at 27thou. and hope. Gerry
Xantia vsx
GSA 1300
Previous AMI8 estate
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
x 94
Unread post by citronut »
the BOL im sure will have the plug gap somewere, have you looked under the ignition section,
i dont have one to hand at the mo but would think 25thou, as that is what most gaps were for that vintage of car,
regards malcolm
scratcher
x 3
AX spark plug gap
Hi, the BOL states that information is given at the begining of the chapter, but it is not there and I can not find it anywhere in the book. Gerry
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
scratcher
x 3
AX spark plug gap
Hi, should have said have said thank you for your reply.Most of the older Cits seem to have been 25thou.
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
If you or anyone else for that matter want a complete set of genuine Citroen AX manuals let me know as I have them gathering dust at work ATM.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
pm sent Richard
regards malcolm
DickieG
x 38
Reply sent Malcolm.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 94
ok i have now looked up in my BOL page 79 ignition system tech data
plug gap on all modles
0.8mm and or 32thou,
regards malcolm
ps.
reply recived and replied to thank Richard
scratcher
x 3
Ax spark plug gap
32thou sounds pretty big, but will try it
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
DickieG
x 38
The AX manuals have now found a new home :D
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 94
Re: Ax spark plug gap
scratcher wrote:32thou sounds pretty big, but will try it
you think thats a big gap you should see what they gap most modern cars plugs at, drive a double decker bus comes to mind,
regards malcolm
scratcher
x 3
AX spark plug gap
Thanks for all the replies, I am used to older cars which had a 25thou gap and that is just the thickness of my thumbnail, there's a handy thing. Gerry
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
