AX spark plug gap
scratcher
- x 3
AX spark plug gap
Hi, I am 'lumbered' with getting my grandsons AX ready for MOT. What is the correct spark plug gap for a just under 1000cc engine? The BOL says it is at the beginning of the relavent chapter-rubbish and the Citroen manuel says that this an important measurement for the efficient running of the car but does not state what it should be. If all else fails I will set it at 27thou. and hope. Gerry
Xantia vsx
GSA 1300
Previous AMI8 estate
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
- x 94
scratcher
- x 3
AX spark plug gap
Hi, the BOL states that information is given at the begining of the chapter, but it is not there and I can not find it anywhere in the book. Gerry
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
scratcher
- x 3
AX spark plug gap
Hi, should have said have said thank you for your reply.Most of the older Cits seem to have been 25thou.
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
DickieG
- Monaco's youngest playboy
- x 33
DickieG
- x 33
- x 94
scratcher
- x 3
Ax spark plug gap
32thou sounds pretty big, but will try it
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
DickieG
- x 33
- x 94
Re: Ax spark plug gap
scratcher wrote:32thou sounds pretty big, but will try it
you think thats a big gap you should see what they gap most modern cars plugs at, drive a double decker bus comes to mind,
regards malcolm
scratcher
- x 3
AX spark plug gap
Thanks for all the replies, I am used to older cars which had a 25thou gap and that is just the thickness of my thumbnail, there's a handy thing. Gerry
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
