Advice needed: Best way to drain diesel from Xantia tank
madscientist
Unread post by madscientist »
Hi, prior to disposing of a Xantie 1.9TD I need to drain surplus diesel from the tank. The Haynes manual suggests syphoning but I thought the fuel inlets were designed to prevent or at least make this difficult - any suggestions.
Xantia HDi SX (2000)
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Lift up the O/S/R seat base, remove the large plastic bung then undo the large plastic ring (use a hammer and a screwdriver if necessary) then remove the sender unit assembly and you will have clear unobstructed access to the lowest section of the tank to syphon from.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 2938
Or do as the dismantlers do, put a bucket underneath and whack the bottom of the tank wth a pickaxe. :D
DickieG
x 33
Hmm, that'll give a rather pungent aroma to your driveway :lol:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 1240
Unread post by Peter.N. »
Or disconnect the fuel line to the pump, extend it and syphon the fuel through that.
gadgetgricey
Unread post by gadgetgricey »
Going to give your hand a good work out, but you could always disconnect the hand syphon priming pump under the engine bay.
Took a while, but I did that and filled three fuel cans.
You get into a rythym after a while :D
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
Are there any parts coming off the vehicle for recycling.
Us xantia owners are always after parts.
Is the engine still running first dibs if it is please.
x 94
Unread post by citronut »
gadgetgricey wrote:Going to give your hand a good work out, but you could always disconnect the hand syphon priming pump under the engine bay.
- Dave -
99 change hands :twisted: :shock: :lol:
i use an electric pump
( from an petrol injection car ) straight into the tank as DickieG (Richard) says,
regards malcolm
