Hi, prior to disposing of a Xantie 1.9TD I need to drain surplus diesel from the tank. The Haynes manual suggests syphoning but I thought the fuel inlets were designed to prevent or at least make this difficult - any suggestions.
Advice needed: Best way to drain diesel from Xantia tank
madscientist
Xantia HDi SX (2000)
DickieG
- Monaco's youngest playboy
- x 38
Lift up the O/S/R seat base, remove the large plastic bung then undo the large plastic ring (use a hammer and a screwdriver if necessary) then remove the sender unit assembly and you will have clear unobstructed access to the lowest section of the tank to syphon from.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 2943
DickieG
- x 38
- x 1239
gadgetgricey
Going to give your hand a good work out, but you could always disconnect the hand syphon priming pump under the engine bay.
Took a while, but I did that and filled three fuel cans.
You get into a rythym after a while
- Dave -
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
wotwot
- (Donor 2021)
- x 4
- x 94
99 change handsgadgetgricey wrote:Going to give your hand a good work out, but you could always disconnect the hand syphon priming pump under the engine bay.
You get into a rythym after a while![]()
- Dave -
i use an electric pump
( from an petrol injection car ) straight into the tank as DickieG (Richard) says,
regards malcolm
