After noon all.
Couple of quick questons for you knowledgeable ones!
S2 estate front discs, do they run the larger 288 mm discs or the older 266mm? Am I correct in thinking they share discs with the V6 and turbo models?
Am creating a list of what to get!
Also, front fog lights, are they H1 or H3? One of mine has died! I looked on ebay but got a bit confused haha some places suggested the main beam, high beam and foglights were all the same size? Handy if so!
Thanks guys!
My main computer has died and held all the techy info I had so am on the tablet (hence the bad spelling and grammar)! and is taking some getting used to!
Edited for clarity.
couple of S2 Xant estate questions!
Timmo
- x 168
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 1480
Chris570
- x 36
Timmo
- x 168
Ah! Yeah 282/ 3certainly rings a bell!
Okay so fog lamps, how on earth do you get to the damn things if youve got normal sized arms! Id ask my 5 year old to help but she wouldnt be able to do the retaining springs! ( previous h1 experience!) I can just about get to the plug but no chance of anytging else!
'58 C2 Code
'58 C2 Code
DickieG
- Monaco's youngest playboy
- x 38
Timmo
- x 168
DickieG
- x 38
I haven't done this for a while but IIRC loosen (or remove) three or four nuts under the front and one or two bolts each side where the wheelarch liner attaches, then in each front wheelarch remove/pull back the front of the liner and remove the self tapper at the inside top of the bumper then pull the bumper forward. As I say I haven't done it for a while but its not as difficult or as lengthy as you think.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Timmo
- x 168
VertVega
- x 13
Correct, mine (2.0i 16V Estate) has 283 mm front disks.RichardW wrote:Only the HDi 110 has the biggest disks (a la V6 and 2.0T) and Bosch brakes. The others have the middle size discs (283 or something).
S2 models fogs are H1, just like head lights (both high and low beam).Timmo wrote:... front fog lights, are they H1 or H3? ...
This tip came from a member as a result of a good team work
Edit: I can't remember his nick but I remember that he had a Xantia S2 Estate white colored
Xaccers
- x 188
Unless the side bolts have rusted up.DickieG wrote:Remove the front bumper! TBH its not that bad a job, 10 mins at most.
DIY sphere tool
DIY sphere tool
Timmo
- x 168
VertVega
- x 13
I found the thread by FCF Search.VertVega wrote:...
-Fog lights can be changed by removing front indicators.
Tip was by member John Plum
If it's MK2 (S2) Xantia, they're definitely type (H1 + H1) and H1
carpysmith
Timmo
- x 168
addo
- Sara Watson's Stalker
- x 95
