couple of S2 Xant estate questions!
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
After noon all.
Couple of quick questons for you knowledgeable ones!
S2 estate front discs, do they run the larger 288 mm discs or the older 266mm? Am I correct in thinking they share discs with the V6 and turbo models?
Am creating a list of what to get!
Also, front fog lights, are they H1 or H3? One of mine has died! I looked on ebay but got a bit confused haha some places suggested the main beam, high beam and foglights were all the same size? Handy if so!
Thanks guys!
My main computer has died and held all the techy info I had so am on the tablet (hence the bad spelling and grammar)! and is taking some getting used to!
Edited for clarity.
'58 C2 Code
'58 partner teepee outdoor
x 1485
Only the HDi 110 has the biggest disks (a la V6 and 2.0T) and Bosch brakes. The others have the middle size discs (283 or something).
Chris570
x 36
Unread post by Chris570 »
yep my hdi 110 has 288mm discs
the fogs are h1 i believe
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
Timmo
(Donor 2022)
x 168
Ah! Yeah 282/ 3certainly rings a bell!
Okay so fog lamps, how on earth do you get to the damn things if youve got normal sized arms! Id ask my 5 year old to help but she wouldnt be able to do the retaining springs! ( previous h1 experience!) I can just about get to the plug but no chance of anytging else!
'58 C2 Code
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Remove the front bumper! TBH its not that bad a job, 10 mins at most.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Timmo
(Donor 2022)
x 168
Seriously?? Okay, so quick how too?? Will grab a pair ofbulbs then, replacethem both, quite fancy yellow bulbs in them (put yellow lamps on the bx and wasmuch better in fog/mizzle!
hmmmn
'58 C2 Code
DickieG
x 38
I haven't done this for a while but IIRC loosen (or remove) three or four nuts under the front and one or two bolts each side where the wheelarch liner attaches, then in each front wheelarch remove/pull back the front of the liner and remove the self tapper at the inside top of the bumper then pull the bumper forward. As I say I haven't done it for a while but its not as difficult or as lengthy as you think.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Timmo
(Donor 2022)
x 168
Cool! Will give it a go when having a car weekend!
ta muchly!
'58 C2 Code
VertVega
x 13
Unread post by VertVega »
RichardW wrote:Only the HDi 110 has the biggest disks (a la V6 and 2.0T) and Bosch brakes. The others have the middle size discs (283 or something).
Correct, mine (2.0i 16V Estate) has 283 mm front disks.
Timmo wrote:... front fog lights, are they H1 or H3? ...
S2 models fogs are H1, just like head lights (both high and low beam).
- :idea: Fog lights can be changed by removing front indicators.
This tip came from a member as a result of a good team work 8-)
Edit: I can't remember his nick but I remember that he had a Xantia S2 Estate white colored :wink:
Xaccers
x 188
Unread post by Xaccers »
DickieG wrote:Remove the front bumper! TBH its not that bad a job, 10 mins at most.
Unless the side bolts have rusted up.
DIY sphere tool
Timmo
(Donor 2022)
x 168
Ideal, thanks for that, seems a lot ofplacs suggest the lights are h7 h7 h1??
Guss easiest way will be pop a bulb out and check,
I'll add the discs to the the list! Thanks.
'58 C2 Code
VertVega
x 13
VertVega wrote:...
I found the thread by FCF Search.
Tip was by member John Plum :) ---> front foglight bulb replacment
If it's MK2 (S2) Xantia, they're definitely type (H1 + H1) and H1 :wink:
carpysmith
Unread post by carpysmith »
Hi there!
both head light and fog lights are definitely h1,s on my my mark 2 xantia (1999). I have changed fog light bulbs on mine by removing indicator! it,s a bit fiddly but not too bad!!!
Regards
Steve (aka carpysmith)
1999 xantia hdi sx (estate)
Timmo
(Donor 2022)
x 168
Had a quick look this avo and indicators are only a small plastic clip so simple removal! Just gotta try and squeeze my arm in the gap!
'58 C2 Code
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I tend to remove the blinker, then the moustache trim, then the headlight - more room (less risk of touching the bulb's glass) and not much extra work.
