Fuel gauge problem
KennyW
x 163
Fuel gauge problem
Unread post by KennyW »
Hi all,
Query, my fuel gauge is working and then not. :?
What could be the likely causes :?:
I'm going to check the wiring in case it is fault or the gauge itself.
Hoping to get a friends garage at the weekend to do some of the other jobs so advice please.
Kenny
C3 1.4 petrol (SWMBO)
rory_perrett
Unread post by rory_perrett »
Had a similar problem with my HDi, gauge was very erratic, sometimes thumping the top of the dash would get it to behave itself for a bit. I concluded the problem was in the instrument pod itself. Eventually got round to changing it for a pod from another car - its worked fine since.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I can tell you EXACTLY what it is after my own experiances!!
Dont even BOTHER wasting time with wiring!! Or even the tank sender!!
Remove the instrument panel clocks, and open them up!
Then behind the speedo face is a small cuircuit board mounted there.. it IS this little board at fault..
What Haynes FAIL to show is that the Tank sender is NOT directly connected to the guage... it has to go through this small cuicuit to conver and process the signal for the guage!! Imagine what your fuel guage would be like going round corners... up / down /up /down...
So this IS what your problem will be!!
Paul
A very sad...
1994 XM 2.1 d auto
x 8252
Did you repair this circuit board Paul or just swap it for a known good one?
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Whether the instrument panel at fault will depend the source of the fault, for instance when I bought the Activa that Jim now has, after starting the gauge would slowly descend to the bottom as if the car was doing single figures MPG. The cause was the fuel tank sender unit.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
CitroJim wrote:Did you repair this circuit board Paul or just swap it for a known good one?
Hi Jim,
No I didn't, and dont ask me were it is now! :lol:
Ive a good few in Mk.1 instrument panels hence the no need to repair it..
Paul
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
DickieG wrote:Whether the instrument panel at fault will depend the source of the fault, for instance when I bought the Activa that Jim now has, after starting the gauge would slowly descend to the bottom as if the car was doing single figures MPG. The cause was the fuel tank sender unit.
The Give away Richard, is the need to thump the dash.. :wink:
Paul
A very sad...
1994 XM 2.1 d auto
x 8252
citroenxm wrote: The Give away Richard, is the need to thump the dash.. :wink:
Ahh, in that case then, the most likely problem is a dry joint on the circuit board :)
DickieG
x 38
Quite, the original poster KennyW makes no mention of thumping the dash hence my post :wink:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Clogzz
x 40
Unread post by Clogzz »
Dry joints on the fuel gauge.
citroenxm
Fallen Hero
x 70
Of Course Richard, I wasnt trying to contridict you... at all!
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
x 38
citroenxm wrote:Of Course Richard, I wasnt trying to contridict you... at all!
No problem, I just thought you'd misread the original post :D
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
KennyW
x 163
Thanks Guys for the replies,
I haven't tried the 'thump the dash board' fix will try tomorrow :wink:
Clogzz thanks for the pic.
Will look at the problem further at the weekend.
Will post a reply after.
Kenny
x 1472
I'm pretty sure Clogzz those are the pins that need to be soldered to fix the speedo sticking at 50 problem.... :?
Clogzz
x 40
Thanks Richard, I’ve had doubts about this picture before. :?
I’ve lost the ‘proper’ one and mistook this one for it. :oops:
I’ll leave it there so as not to corrupt the thread and will trawl for the proper one.
