I've got a december 2005 citroen C8 2.2HDi and i would like to retrofit cruise control.
I've got Lexia 3 on my laptop and used it to succesfully install the genuine citroen towing electrics kit which was dead easy.
Using Lexia i'm looking for options regarding cruise control to make sure it's possible before i invest in the switch stalk but the only reference that i can find is on fault code reading.
Can anyone confirm if it is possible to do and how to do it?
Lexia and C8 cruise control.
DickieG
- Monaco's youngest playboy
- x 38
Search on the forum for fitting cruise to other models such as a C5 as I think there are threads stating how to do it. IIRC you need to look for 'RVV' and activate that + maybe one other thing.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1056
Richiejh
Thanks for the info, I'm going to connect up tomorrow and try and find the RVV and injection ECU options.
There are a number of rumours floating around that the cruise control activation operation was disabled on either car or lexia software at some point, this was apparently to stop dealers fitting CC to cars in the workshop for less than the option when new. The factory option was near £400 but the parts and labour cost more like £100.
That would be typical of a manufacturer to protect their income.
Citroenmad
- x 110
Im not sure with the C8 but with the C5s some cars need a secondary brake switch installing to allow the cruise to work. I fitted it on my 2004 C5 and it worked fine just by adding the stalk and programming the car to have cruise with a Lexia.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
sifaan
Re: Lexia and C8 cruise control.
preconditions for cruise controlRichiejh wrote:Hi,
I've got a december 2005 Citroën C8 2.2HDi and i would like to retrofit cruise control.
I've got Lexia 3 on my laptop and used it to succesfully install the genuine Citroën towing electrics kit which was dead easy.
car must have motorized throttle body - on C5s only the earliest (RPO upto 9443) had cables so this was not much of an issue; no idea how it is with C8s.
you will need an additional brake switch (if there's only 1, it's for the lights) and (I think) also a clutch switch if it's a manual.
my C5 was auto, but had the brake switch even though it didn't come with CC
if you don't have a motorized throttle, then lexia may well be not showing the option for you...
- x 1056
Richiejh
Richiejh
manafas
- x 3
Hello
I know this was some time ago, but did you have any luck installing the CC on your C8?
Trying to do the same
Thank you
Thank you
- x 1918
Richiejh last visited the forum on Tue Jul 12 2011 at 9:29 pm so I doubt you'll get reply from him!
