Hi, when changing gear from second gear to third or fourth to fith I hear a squeak , only moving from those gears , anybody got any ideas ?
cheers Terry
gearbox squeak
froggy
- (Donor 2026)
- x 4
gearbox squeak
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
jgra1
- (Donor 2021)
- x 36
addo
- Sara Watson's Stalker
- x 95
jmd
- x 1504
froggy
- (Donor 2026)
- x 4
Xantia gearbox squeak
It"s when you move the gear lever, it sqeaks with engine runnnig or switched off. only moving from 3 to 4 or 4 to 5, never 1to 2 or 3 to 4 .
thanks for your help.
cheers Terry
cheers Terry
Terry
froggy
- (Donor 2026)
- x 4
gearbox squeak
Which is the best lube to lubricate the selectors ?
cheers Terry
cheers Terry
Terry
- x 8457
Re: gearbox squeak
The only real way is to carefully disengage the rod balljoints, being incredibly careful not to stress the rubber mounted ones, clean the balls and ballcups thoroughly and smear on a the tiniest film of normal grease on the balls and reassemble. If you use too much grease you'll not get the ballcups back on as they will hydraulically lock.froggy wrote:Which is the best lube to lubricate the selectors ?
cheers Terry
The balljoints themselves near the gearbox may not be the problem. There's bellcranks under the gearstick itself and it's likely these are dry and squeaking. Also there's a pivot on the subframe and a big hollow rubber ball on the subframe pivot that could conceivably squeak. That would need lubricating with rubber grease or silicone spray.
To really determine the cause, jack up and support the car and then climb under and listen carefully whilst someone else wiggles the gearstick.
