gearbox squeak
froggy
(Donor 2026)
x 4
gearbox squeak
Unread post by froggy »
Hi, when changing gear from second gear to third or fourth to fith I hear a squeak , only moving from those gears , anybody got any ideas ?
cheers Terry
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Terry.. for the sake of a few mins work I would get some lube on the selector joints at the RH back of the engine.. may need to pull the airbox out of the way etc.. I think there are 3 rods, i.e. 6 ends..
can't think what else would cause it...
john
addo
Sara Watson's Stalker
x 95
Unread post by addo »
jgra1 wrote:...can't think what else would cause it...
jgra1
(Donor 2021)
x 36
:twisted:
jmd
Unread post by jmd »
I had a similar problem to yours about two years ago, with my Mark 2 Xantia. I changed the oil in the gearbox & have had no problems since. Drain completely and refill.
x 1488
What sort of squeak and when?
Just as the lever is moved, or as the clutch is re-engaged. Does it do it with the engine on and off, does it do it if you just change gear when stationary?
froggy
(Donor 2026)
x 4
Xantia gearbox squeak
It"s when you move the gear lever, it sqeaks with engine runnnig or switched off. only moving from 3 to 4 or 4 to 5, never 1to 2 or 3 to 4 .
thanks for your help.
cheers Terry
Terry
froggy
(Donor 2026)
x 4
gearbox squeak
Which is the best lube to lubricate the selectors ?
cheers Terry
Terry
x 8389
Re: gearbox squeak
froggy wrote:Which is the best lube to lubricate the selectors ?
cheers Terry
The only real way is to carefully disengage the rod balljoints, being incredibly careful not to stress the rubber mounted ones, clean the balls and ballcups thoroughly and smear on a the tiniest film of normal grease on the balls and reassemble. If you use too much grease you'll not get the ballcups back on as they will hydraulically lock.
The balljoints themselves near the gearbox may not be the problem. There's bellcranks under the gearstick itself and it's likely these are dry and squeaking. Also there's a pivot on the subframe and a big hollow rubber ball on the subframe pivot that could conceivably squeak. That would need lubricating with rubber grease or silicone spray.
To really determine the cause, jack up and support the car and then climb under and listen carefully whilst someone else wiggles the gearstick.
