smokey veg xantia
imperial21
smokey veg xantia
Unread post by imperial21 »
Do the xantia smoke more when running on veg oil ? i am using SVO.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
XantiaDaveEire
x 4
Unread post by XantiaDaveEire »
Mine didn't ,except for when i put the boot down :lol:
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
Xaccers
x 188
Unread post by Xaccers »
Mine smoke less.
If it's smokey then air could be getting in, otherwise if it's when you start then change your glow plugs.
DIY sphere tool
imperial21
Humm, I was expecting the results you say, I am not sure if the car was smokey to start with ! I just followed the car up the road as it gets warmer it smokes more then goes away a bit until you slow down to stop, its blue smoke which is oil being burnt. I guess its probably rings as the car car has done 145k. the car is a 1.9 xud.
Xantidote
x 4
Unread post by Xantidote »
Another option would be the valve stem seals
Martin
1995 Xantia TDLX (deceased :( )
