smokey veg xantia
imperial21
smokey veg xantia
Do the xantia smoke more when running on veg oil ? i am using SVO.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
XantiaDaveEire
- x 4
Xaccers
- x 188
Mine smoke less.
If it's smokey then air could be getting in, otherwise if it's when you start then change your glow plugs.
DIY sphere tool
DIY sphere tool
imperial21
Humm, I was expecting the results you say, I am not sure if the car was smokey to start with ! I just followed the car up the road as it gets warmer it smokes more then goes away a bit until you slow down to stop, its blue smoke which is oil being burnt. I guess its probably rings as the car car has done 145k. the car is a 1.9 xud.
Xantidote
- x 4
