the AC in my 58 plate C5 does nothing...the air is no colder with it ONthan with it OFF....
C5 Aircon
411514
- (Donor 2017)
- x 40
Could be a can of worms but could be something relatively simple,
check, connection on the coolant pipes a loose connection will allow the gas to escape,
wiring plug come off the compressor,
electromagnetic compressor clutch stuck or fallen off,
if its none of these then i think you would have to entrust it to a dealer or autoelectrician as correct me if im wrong such a new car has climate control and any air con ouput would be regulated by a thermostat of some sort
Clogzz
- x 40
If the compressor kicks in, it’s a good start and it may only need a re-gas.
Even with low gas and compressor running, you should hear a slight hiss from the centre vents.
If the compressor is not running, the gas pressure may be very low and an aircon mob will have to test for that.
hdi_man
Citroenmad
- x 110
It should still be under warranty is it? Time to take it back, again!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
hdi_man
- x 1431
I would suggest that a good independent A/C technician would be better value than a Citroen dealer for this job.hdi_man wrote:well got the system re-gassed for £50 at Kwik-fit and all was brilliant for 1 week....then it seems all the gas is gone again !!![]()
back to kwik-fit and they say their machine says no leak, so must be slow leak and need to goto dealers.....
Citroenmad
- x 110
Did quick-fit not put in a coloured die to help find the leak?
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
hdi_man
peterdk
Re: C5 Aircon
A machine cant always detect a leak. The correct way to test for leak, in addition to using dye, is to leave high pressure on the system overnight and then see in the morning how much it dropped.
A really silly thing could be the schraeder valves themselves! As long as the coupling is on, the valve doesnt leak, right? And then you leave the shop, and *fissssssss*
oneday
Re: C5 Aircon
quick fit have no ac engineers they put it on a machine and press go. leak checking is done by the machine pulling a small vac this alone can seal a leak and not detect it. the only way to find a leak is with the system pressurized. introduce dye use a leak detector a good ac engineer will allways check for leaks in a state of deep vac and at pressure.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Napoleon
- x 4
Re: C5 Aircon
FWIW, my aircon guy tested for gas in the C5 and found none, then tested with nitrogen and we both heard, quite clearly, the hissing of gas from near/at the condensor.
No need for a stealer, just a qualified aircon guy who knows what he's doing.
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
2009 HV09 C5 2.2
Tarte au Citroen
welshspark
- New User
Re: C5 Aircon
Does anyone now where the relay for the aircon clutch is located on a c5 tourer? Is there a relay or is it an output from the ECU? Does anyone have any info on the location on the pressure switches on the aircon unit? My unit isn't working and I've found that the electric clutch isn't getting a signal to pull in. Trying to establish if it's just not getting the signal due to a relay or similar or if it's being stopped by a pressure switch, too high or too low. Any help would be appreciated
