xantia heater matrix pipe re fit
imperial21
Unread post by imperial21 »
Hi All
Can i get any help with fitting the twin engine pipe into my new heater matrix, we have pushed very hard, it makes the O ring squash out ? :twisted: but we can get the pipe to lock in, its nearly my last job now !!!!
please help !!!!!! [-o<
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
citrov6
Unread post by citrov6 »
Its been a couple years since I did it but I think I put the o rings on the pipe side then squeezed it on to the matrix. It doesn't work if you put the o-rings on the heater matrix. Be very careful not to break it its tricky
Love my black v6 xant - only one with cream coloured leather too!
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The only way I've managed to get them back on is to carefully locate the rubber rings on the ridge in the matrix then push the plastic pipes in, I found that smearing the surfaces in Vaseline helped it slide together.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8462
I've tried it both ways and come down in favour of putting the rings on the pipe stubs. If one way doesn't work, try the other...
The secret, as Richard says above, is lots of Vaseline! Lube really does make it all slide much easier.
Also, use new O rings. (Part No. 6464 V1) old ones seem to swell a bit and are hard, in my experience, to re-use...
It's vital that the elbow goes home with a satisfying click...
imperial21
I have put new O rings on and put some vaseline on it,maybe i should try more vaseline !! :lol: is there any particular way to push that works best ?
Xaccers
x 188
Unread post by Xaccers »
With Juliet there was no way i could get the pipes to fit and click into place with the o-rings fitted, they'd seem to be home, but if I floored it they'd get blown off and I'd lose all my coolant.
So i tried without the o-rings, they clicked into place and I've never had a link.
However, that is with (possibly different) Berlingo pipes we had to fit as the original ones cracked.
DIY sphere tool
Xantidote
x 4
Unread post by Xantidote »
I struggled initially, refitting mine. After 2-3 attempts, placed the new O-rings about 3mm from the end of the tapered connector (?), and it slid home with satisfying click. I used a bit of fairey liquid, rather than vaseline.
Martin
1995 Xantia TDLX (deceased :( )
x 5689
You may be OK as it is only a very small amount but the danger with detergents is foaming and airlocks forming.
Vaseline is reported to degrade rubber seals of course, as is any petroleum based lubricant.
Probably safest is neat antifreeze which is pretty slippery stuff and made to be there.
Xaccers
x 188
Or silicon grease/spray
DIY sphere tool
DickieG
x 33
Or KY jelly :lol: joking aside possibly the best stuff to use being water based.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I found a trick is a bit of Fairy Liquid on the O rings, and place them on or near the ENDS of the pipes NOT in the matrix...
Ive also had no effects of bubbles either.. :D :D :lol:
Paul
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
as said above have them at the tip of the tapered pipe ends and as they slide in as long as they are lubed they slide/roll back and seal in...
citroenxm
Fallen Hero
x 70
Sorry. . I miss the point.. spongebob and pipe fitting???? :? :)
Paul
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
hes a lilly livered bubble blower..
Fairy liquid... bubbles :D
imperial21
I have borroweed some silicone grease and will see how it goes later, fingers crossed !!!!
should i grease the matrix pipes too ???????
