My Xantia V6 Blog ....SADLY Due to End.. :-(
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all...
Well, finally made a start on my V6 Xantia Repair by strippin her down.
Car: 1997 P reg, Early Xantia V6 24v Auto.
Things to do...
Strut feed pipes badly corroded along most of the pipes.
ABS Not working, 3 sensors are away.
Lower engine mount rubber completely missing - completely AWOL
Front bumper damaged, new one got, needs spray.
Proper passenger wing to fit.. currenttly a standard one fitted.
Cam belt, water pump need changing as a matter of course.
Exhaust not blowing but not exactly tidy either...
Tyres to go the original alloys
Miss fire on the engine ONLY when cold
Rear electro valve is buggered too - according to Lexia anyway.
Anyway... made a start..
Above: Front bumper off, headlights off, fans off, headlight cross panel off
Above: Front on view.
Below: Some of the pipe work needing attention:
Below: PAS Return pipe hole... pipe looks a standard pipe connected lower down.
Below: Dodgy Air Con pipes
Below: Messy HP Pump here
Thats the strip down so far, having a look around at what needs dooig here.
Wey hey, I also found an Auto Box dip stick... I pulled it out and the autobox fluid smelt, clean, un burnt, and red ish... Thats GOOD news to me...
Paul
A very sad...
1994 XM 2.1 d auto
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
You're a glutton for punishment. :wink: I going to enjoy keeping an eye on this project.
Steve
http://c6owners.org/index.php
citroenxm
Fallen Hero
x 70
Hey steve... Nah.. All easy stuff this :O as long as the off side drive syaft comes out the house easyilly then that shouldnt be too bad.... :-$ :-)
Paul
A very sad...
1994 XM 2.1 d auto
Trainman
(Donor 2018)
x 43
citroenxm wrote:Hey steve... Nah.. All easy stuff this :O as long as the off side drive syaft comes out the house easyilly then that shouldnt be too bad.... :-$ :-)
Paul
Famous last words.................. buddy
Steve
Deanxm
x 87
Unread post by Deanxm »
Isnt the esso spec fluid for these boxes clear? i thought only Dex2 was red........
Sorry Paul but just a thought.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
citroenxm
Fallen Hero
x 70
Yes of course... It was clearish not red.. I forgot these boxs had esso not dex....
Paul
A very sad...
1994 XM 2.1 d auto
Deanxm
x 87
Lucky anyway, having the early one with the dipstick will make fluid changes simple.
It looks like a nice car Paul
D
XM Prestige PRV6 92
Xantic
x 11
Unread post by Xantic »
I don't have time to change my mind yet alone all that your doing Paul.
Good luck mate..
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
citroenxm
Fallen Hero
x 70
This is the first of 4 to do... Ive also got a 1991 xm sed to work on, a 1993 xm v6 sei, and a hdi 110 xantia to do..... =-O
A very sad...
1994 XM 2.1 d auto
x 8173
Well done Paul :D
Good project!!!!
The centre bearing will be easy. You just need a nice long, slim cold chisel and a BIG hammer!!
What are you planning with the crusty Hydractive pipes?
I've been all over the same areas of a V6 like a rash, been there, done that and so on. Get in touch if you need advice or a shoulder to cry on...
citroenxm
Fallen Hero
x 70
Well I was gonna change the pipes for better looking S2 Pipes from a HDi Exclusive, however, the Hydractive block is at a different position and so the pipes are a different shape, so I cannot swap them...
Ill remove them, clean them up and see how thin they are once Ive finished... coat them with an anti rust again and re-fit them...
The drivers one is all clear to come off, but the passenger one is a bit more complex with the wiring loom passin over the top of it to the main fuse box...
Paul
A very sad...
1994 XM 2.1 d auto
x 1392
Unread post by xantia_v6 »
With all the work you are doing there, you might as well lift the engine out and change the transmission filter for peace of mind for another 100,000 miles!
citroenxm
Fallen Hero
x 70
Hi xantiav6..
I had originally intrnded removing the whole lot but not sure i nee to now.. Where is the filter on them.?
Paul
A very sad...
1994 XM 2.1 d auto
Deanxm
x 87
the filter is in the box, you just need to split the case i think, i say 'just' but if its anything like the HP18 splitting the case is very easy. once you have the box out of course
D :lol:
XM Prestige PRV6 92
x 1392
citroenxm wrote:Hi xantiav6..
Paul
See here (courtesy Jim)
It is the black thing at the bottom of the picture.
