ANOTHER PROBLEM !
hdi_man
ANOTHER PROBLEM !
Unread post by hdi_man »
unbelievable really, car due into dealer this week for slipping clutch...today when cleaning car a tyre value just crumbed in my hand and all the air rushed out ! - on goes spare.
should have known better as same thing happened on my pug 207...WHY do the french decide to use metal valves !?!?! :roll:
so many problems with this C5 its really becoming a joke now
x 8466
:shock:
That's not good...
Is this one of those wheels with pressure monitoring?
hdi_man
yes its a common problem on PSA cars, pressure sensor valves are METAL...salt on roads in winter means the simply corrode away. its just a plain stupid design flaw !
if its out of warranty dealer wants £60 for new valve and £60 for fitting !
x 94
Unread post by citronut »
so the valve failes then the system know's it aint got any air in it :shock: ,
regards malcolm
wright
Unread post by wright »
i would just get it turned off, i've never had it and i don't see a great need for it, i think its a way for the dealers to make money, almost any car i've seen it on needed at least one valve at fair expense, it doesn't seem to be a reliable system on any car
02 C5 2.0 hdi 110
handyman
Unread post by handyman »
Would you not fall foul of the MOT if this is going to be included and it did not work properly? If it was fitted as an OE standard, then turning it off or removing it would leave the car subject to a failure.
Is it possible to fit a normal Schrader valve in the rim, in place of this new fangled piece of junk? As I am a bit of a Luddite, I've not seen one of these valves close up to see what has been done to the rim to enable fitment.
Sometimes this "advancing" technology is just a sop to sad people that want a new gismo on their car, irrespective of its true value.
I am still trying to understand why they phased out manifold driven windscreen wipers. [-X [-X :dunno:
H
x 5689
H
If you mean the pneumatic things they had on the old Vauxhall Cresta then no doubt it's because they were rubbish.
handyman
Steve, one word - sarcasm. :roll:
H
x 5689
Thought as much - glad you weren't serious, they were absolutely dismal.
Citroenmad
x 110
Unread post by Citroenmad »
I think there was another thread about this very recently.
Thankfully this is not a problem earlier C5s seem to suffer with. Though it doesn't make me want tyre pressure monitors any more than I did :lol:
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1955
Unread post by Paul-R »
handyman wrote:Would you not fall foul of the MOT if this is going to be included and it did not work properly? If it was fitted as an OE standard, then turning it off or removing it would leave the car subject to a failure.
Not yet. My C5 went through with the MOT with the warning on the multi-function display showing.
I've since turned the option off with my Lexia so I think that might satisfy the future MOT.
If not, they can certainly be replaced with ordinary valves and providing the option is turned off there's every chance it'll pass the future MOT.
Apart from that these changes are rarely retrospective (I can only think of front seat belts in the sixties that were) so it'll only affect new cars, surely.
