Hi, I want to change the gearbox oil in my 1997 1.9 TD . [Xantia ]
Do I need any special tools? What type of gearbox oil should I use ? My local Citroen dealer uses " Total " .
many thanks Terry.
Xantia Gearbox
VertVega
- x 13
Hi, You have forgotten to mention if its a manual or automatic gearbox.
Manual Gearbox:
I have manual 5 speed (BE3) and I use Total 75W-80, capacity 1.8 liters (simply pour 2 liters
I use only wrench tool to undo the drain plug and always change the copper seal.
Manual Gearbox:
KennyW
- x 165
Good Morning Terry,
No special tools required but make sure you use the correct grade of gear oil ie 75w/80 semi/synthetic gear oil or 75W/90 spec API GL5 approx 2 litres is required.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 5689
