Xantia Clutch cable
EDD
Xantia Clutch cable
Unread post by EDD »
I have read about the many problems you chaps have had fitting the clutch cable to the pedal.I was wondering if any xantia owners have taken the instrument console out to see if it's possible to gain access to the dreaded clip.
EDD
marco1
Unread post by marco1 »
no need but its an awfull job but i can do it in about an hour and a bit now ...its still not nice though
shaunthesheep
Unread post by shaunthesheep »
i've found the best way to replace the clip is to remove the drivers seat, lay down so your head & face is looking up at the top of the pedal & do it that way, if you read up about 'removing the instrument panel[}:)][}:)]' it's a lot harder than you think.
dom
EDD
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by marco1</i>
Thanks for the reply Marco one of the reasons I asked is that I have a couple of bulbs out.
x 1060
Unread post by wheeler »
once the instrument cluster is removed is removed there is a hole behind it where you can get at the clip,its not the easiest way though.
EDD
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by shaunthesheep</i>
dom
