Hydraulic pump O ring size ?
HDI
x 7
Unread post by HDI »
The O ring on the valve which screws into the hydraulic pump has blown on my HDI :x
Managed to bodge it with PTFE tape temporarily.
Does anyone know the O ring dimensions please ? Will get one from the local belt and bearings place.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
DHallworth
x 173
Unread post by DHallworth »
I've got some at home for my XM. If it's the same ones I'm thinking of then the pumps look the same between them.
I'll measure them tonight if I get the chance.
Citroen sell these and my local dealer had them on the shelf. They were less then a quid each from memory.
David.
'98 Xantia Activa V6 :-D
'13 Renault Zoe - Broken
'15 C4 BlueHDi Feel - For Sale
kenhall1202
Unread post by kenhall1202 »
Two (of 3) types of O ring listed for the 6+2 pump are 16x1.9 and 19x2.4.
Ken Hall
x 94
Unread post by citronut »
here is part No.'s and dimentions, and there are two diferent sized bungs/plugs in one pump,
4026 87
HYD OIL O-RING
DIAM 16-TO 1,9
- PRESS PUMP 6+2 + NON-SINKING
4026 86
HYD OIL O-RING
DIAM 19-TO 2,4
and here is part No. and price
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000402688 HYD OIL O-RING 1.16 GBP 1.39 GBP 1.39 GBP
0000402687 HYD OIL O-RING 1.36 GBP 1.63 GBP 1.63 GBP
regards malcolm
HDI
x 7
Thanks guys :D
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Xaccers
x 188
Unread post by Xaccers »
When you say valve, do you mean the 17mm hex which the pipe comes out of?
If so, get two of the o-rings and replace the one under the similar blanking plate further around the pump.
You could also get the large o-ring that goes between the pump and the powersteering bell end and replace that.
DIY sphere tool
HDI
x 7
Yes, that sounds like the one except it's a 19mm hex. The main pressure feed does take off from it.
There is a bit of a story behind the problem. The original O ring started to cause a slight leak and I replaced it with one from my assortment box, but I don't think the size was quite right hence the subsequent failure.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Xaccers
x 188
Thought I was wrong with saying 17mm :)
Get theco-rings from the dealer as they're so cheap
DIY sphere tool
HDI
x 7
My local dealer would never have them in stock, they no longer even stock LHM !!!
There is a local belt and bearing place that sells this sort of stuff, from experience I know they will will be about £0.40 each !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 94
trouble is useing any old O ring they might not like diesel fuel, so i think it is better to use one from citroen,
regards malcolm
HDI
x 7
It's on the hydraulic pump not the diesel pump, but it's ok, nitrile O rings will resist either.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 94
sorry what was i thinking :oops: :shock: :wink:
regards malcolm
