When I turn the steering wheel, it frequently feels heavy as if there is not enough pressure working it. This happens for a fraction of a turn, then becomes free/normal. It feels, to a lesser extent, as if you're trying to turn the wheel with the engine off.
Any ideas, my garage feels it could need a new rack? but are not positive that it would cure it.
Steering fault 2000 Forte HDI
- x 8466
Xantidote
- x 4
imperial21
- x 8466
citroenxm
- Fallen Hero
- x 70
You dont EVEN need to remove the front wheel!!!
Put the car on high LEAVE the engine running, then put the steering on full LEFT LOCK and look along the track rod, and you can see the lower UJ joint!!
These are VERY common for siezing up in on direction..
PLEANTY PLEANTY of freeing agent, WD, Plus gas etc etc and then do a turn lock to lock a few times - a good few times, you may want to jack up the front to take the weight off the front wheels to help reduce tyre wear when turning lock to lock...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
imperial21
Thanks Paul & Jim, I have just gone outside in the dark and done as paul sugested ! The steering was nt returning after going round corners and felt sticky, I will have a proper go at it a weekend, i have sprayed loads of wd40 over it and the covered it in motor cycle chain grease for now. I think that will be a service item for me now on ! Its very rusty ! ! looks nasty to change!
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
citroenxm
- Fallen Hero
- x 70
Beleve it or NOT its fairly EASY to change!! You can EVEN leave the Rack in place !!!
The colum in the car needs to come off, then you undo the pich nut - with a 6mm Alen Key on an extension - The hlafords type that goes on the 1/4in ratchet...
then you can pop it off the pinion and slide it out back towards the rack and out... all from in the wheel arch...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
