Steering fault 2000 Forte HDI
billlew
Unread post by billlew »
When I turn the steering wheel, it frequently feels heavy as if there is not enough pressure working it. This happens for a fraction of a turn, then becomes free/normal. It feels, to a lesser extent, as if you're trying to turn the wheel with the engine off.
Any ideas, my garage feels it could need a new rack? but are not positive that it would cure it.
x 8397
No, it's not the rack Bill, more than likely a bit of corrosion and stiffness in the universal joint between the pinion valve and the steering column. it's exposed and gets a bit wet and cruddy.
Give it a good clean and lube and likely all will be happy...
Xantidote
x 4
Unread post by Xantidote »
If you're feeling very lazy, just try spraying it with aerosol grease and see if that improves things. Not as thorough as Jim's method though
Martin
imperial21
Unread post by imperial21 »
My xantia has the same problem, whats the best way at getting at the joint ?
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
x 8397
Slip off the OS front wheel and peer up above the rack, the joint will be seen between the rack and the bulkhead where the steering column passes into the passenger compartment.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
You dont EVEN need to remove the front wheel!!!
Put the car on high LEAVE the engine running, then put the steering on full LEFT LOCK and look along the track rod, and you can see the lower UJ joint!!
These are VERY common for siezing up in on direction..
PLEANTY PLEANTY of freeing agent, WD, Plus gas etc etc and then do a turn lock to lock a few times - a good few times, you may want to jack up the front to take the weight off the front wheels to help reduce tyre wear when turning lock to lock...
Paul
A very sad...
1994 XM 2.1 d auto
imperial21
Thanks Paul & Jim, I have just gone outside in the dark and done as paul sugested ! The steering was nt returning after going round corners and felt sticky, I will have a proper go at it a weekend, i have sprayed loads of wd40 over it and the covered it in motor cycle chain grease for now. I think that will be a service item for me now on ! Its very rusty ! ! looks nasty to change!
citroenxm
Fallen Hero
x 70
Beleve it or NOT its fairly EASY to change!! You can EVEN leave the Rack in place !!!
The colum in the car needs to come off, then you undo the pich nut - with a 6mm Alen Key on an extension - The hlafords type that goes on the 1/4in ratchet...
then you can pop it off the pinion and slide it out back towards the rack and out... all from in the wheel arch...
Paul
A very sad...
1994 XM 2.1 d auto
