Xantia 2.0 CT Plug Gap?
Diabolical
Unread post by Diabolical »
Does the Xantia 2.0 CT have a different spark plug than the 2.0 recommended 0.7mm :?:
David
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
x 8457
No so far as I know David. 0.7 mm sounds about right.
Why do you ask?
wright
Unread post by wright »
according to autodata the gap seems to change depending on the make of plug, is it 8 valve?
x 8457
wright wrote: is it 8 valve?
Yes it is. Engine code RGX (XU10J2CTE)...
wright
According to autodata the closest i can find is RGX(XU10J2E) listed as 2.0 turbo
Eyquem RFC58LS2E
BERU 14FR-6LDU
NGK BKR6EK
all 0,9mm
BOSCH FR6LDC
0,8mm
XantiaMan
x 18
Unread post by XantiaMan »
.7mm is too small, 1mm is about right if all the other components are working fine, you want a gap as big as possible without it blowing out on boost or misfiring. I never used to run .7mm on the Maestro and that had a dizzy based ignition system and conventional coil, the Xantia has much more ignition power so use it!
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
wright
RFX(XU10J2C/Z) 2.0 NON TURBO
NGK BCPR6E-VG
0,7 mm
BOSCH FR7DCO 07.95.=FR8LDC
0,8 07.95.=0,9 mm
BERU 14FR-7DU 07.95.=14FR-8LDU4
0,8 mm
CHAMPION RC9YCC 07.97.=RC10MC
0,8 mm
AUTOLITE APP3923
0,9 06.95.=0,8 mm
HansNOR
x 7
Re: Xantia 2.0 CT Plug Gap?
Unread post by HansNOR »
So what do you guys run ? :)
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
HansNOR wrote:So what do you guys run ? :)
Whatever they come out the box gapped as these days, I don't think plugs have needed gapping for many years unless you're using some crazy state of tune. I've never had an issue.
daviemck2006
x 485
Unread post by daviemck2006 »
I'm with you there Benc5 just out the box and into the engine. I did that with the 205 and the 107. Can't remember if I changed them on the Megane.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
