David
Xantia 2.0 CT Plug Gap?
Diabolical
Does the Xantia 2.0 CT have a different spark plug than the 2.0 recommended 0.7mm
David
David
06 C5 2.0L HDi Exclusive Estate 20020k and rising.
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
citroencx.co.uk
- x 8330
wright
- x 8330
wright
XantiaMan
- x 18
.7mm is too small, 1mm is about right if all the other components are working fine, you want a gap as big as possible without it blowing out on boost or misfiring. I never used to run .7mm on the Maestro and that had a dizzy based ignition system and conventional coil, the Xantia has much more ignition power so use it!
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
2017 Fiesta ST
wright
HansNOR
- x 7
Re: Xantia 2.0 CT Plug Gap?
So what do you guys run ?
BenC5HDi
- Not Mike
- x 45
Whatever they come out the box gapped as these days, I don't think plugs have needed gapping for many years unless you're using some crazy state of tune. I've never had an issue.HansNOR wrote:So what do you guys run ?
daviemck2006
- x 496
I'm with you there Benc5 just out the box and into the engine. I did that with the 205 and the 107. Can't remember if I changed them on the Megane.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
